CLUNK noise when I Stop
OnlySonoma
Member
BC CANADA
When I use my breaks and stop fairly quick, there's quite a loud clunk noise that seems to be coming from the front passenger side. There isn't any noise coming from it when i'm driving, only when I come to a stop. :confused:
I've already changed the Tie Rods, Pitman Arm, and Centerlink with no luck!
Could the wheel bearing be the cause?:confused:
What else should I check?
At this point, I have not changed any more parts.
It is still making the noise but i'm almost certain that a ball joint is the cause.
Update
FOUND THE PROBLEM
The rear mount for my passenger side upper control arm is loose and when i come to a fast stop it bangs against the exhaust manifold..
I will need to replace the upper control arm as it is not reparable.
Does anybody have any advice for replacing the upper control arm?
My 1995 Sonoma has a strangely designed Upper control arm that does not look like the conventional type.
