I have a 2002 GMC Sonoma sls 2wd standard cab with the 2.2 4cyl.
The fan clutch was bad so instead of replacing that I bought a 16" electric fan. I just did the work this morning and everything seemed fine. The fan kicks on like it should but the temp never drops back down. I am thinking it may be the water pump but I want a second opinion.
Here are the symptoms. The truck heats up, the fan kicks on, it hits 190 degrees and I shut the truck off. The top radiator hose is quite hot but the bottom one is just warm. Against my better judgment I took the radiator cap off and the coolant in the opening was just luke warm. I started the truck with the cap off and saw no flow at all. Any ideas?
Edit, forgot to add. If I squeeze the bottom hose I can hear a gurgle from around the top hose.
Edit again: Forgot to mention that it is also a brand new radiator. The old one was leaking so I replaced it too.
