correct tire pressure, sticker gone
961kyle
the sticker on the door jam that usually has the correct tire pressure is gone and i cant find it anywhere, does anyone know what the correct tire pressure is for a 94 gmc suburban?
En général, la pression sur les pneux ce situe entre 35lbs et 40lbs pressions, selon la saisons.....
32PSI was recommended, but you can also go by the tire pressure on the tire it self. There is a max pressure on the tire that you should not exceed, which could be 44psi, depends on the make of the tire and the recommended tire pressure on the door jam is the suggested pressure for the best comfort ride of the Suburban. Hope this helps explain the tire pressure class 101:D
