Desperate help! blinker problem on my work van!
Bitemefordboy
Sooo, i hooked my trailer lights up, i used the snap splicer apparatus to connect my lights on my trailer, well, a pressure washer was set right inside my back door, right ontop of that harness, from the friction of the pressure washer bumping about in the back it broke the plastic coating and grounded two wires out, now my whole left side is dead in the back of the van, only running lights work, no blinker, no brake, no reverse, i inspected what wire i could inspect and no viewable damage, is there an inline fuse that may have blown? i checked the ones under the hood and they are good, the right side works perfect, even the top brake light with two bulbs works, accept the left bulb,, i need help! please and thank you,,
Damian
noone has any idea on what the problem is? has anyone ever tore apart one of these? i have no idea as far as automotive electronics throw me any ideas...please...
much appreciated,
Damian
well if you don't know how dc volts work then i suggest you take it to a good shop (not a chain name or a dealer) but a repair shop.
It will most likly be a easy fix (hour labor or so) you could spend hours and hours looking and find nothing if you don't know how it works.
Good luck
