goingcrazy2fix
- Dec 2, 2015
I have 95 gmc c1500 4.3l 2 door standard cab - vin "Z"
RPO code in glove box shows -> GU6 = 3.42 ratio.
FLUID LEVELS ?????
Amsoil shows the following for
Differential, With 10.5 RingGear With D Rear..........5.5 pints
Differential, With 10.5 RingGear W/O Rear..........7.2 pints
Differential, With 12 RingGear Rockwe Rear..........13.9 pints
Differential, With 8.5, 8.625 R Rear..........4.2 pints
Differential, With 9.5 RingGear Rear..........5.5 pints
Differential, With 9.75 RingGear Rear..........5.5 pints
between 4.2 qts and 13.9 qts ??????
Ratio and ring gear ???? GU6 tells me nothing.
Questions :
1.) Any ide of how much gear oil I need to buy in advance ?
2.) Is Lucas # 10047 is 75w-90 full syn the right stuff ?
FLUID LEVELS ?????
Questions :
