Disable stabilitrak in 2004 gmc sierra?
Spartan
I was wondering how to shutoff the stabilitrak option in my 04 sierra, everyones says its on the shifter leaver but my trucks and automatic and there is no button to shut it off anywhere else, i know it has it beacuse when the truck slips hard the dashlight comes on, anyone know how to shut it off by pulling a fuse or something else because its hurting my speed when me and my friends race on the strip, thanks
Ok for you all tire burners, GM adds a thing called "Torque Management" into all of the 99 and newer model trucks w/ V8's. What this is for so Gm can pass emission testing and some kind of other safety issues, but in the mean time all it does it kill your power when your trying to spin your wheel or when you start off hard...basically it kills your power until the truck sees that you really need the power then it lets you have it like when passing someone. Its a pain when trying to do burnouts, but you can get it removed with a HP tuner or Tech2 I believe. (check with that though and most transmission shop will have a tech2 scanner) ;)
I found that when power-braking, the rpm wont go above a certain mark (1,800 RPM) but the tires will spin no problem at all(maybe enuff to get a little smoke goin), but once i let off the brake the rpms shoot up and the tires smoke like crazy almost instantly. Waking up the beast, however the torque management is still activated. :eek:
