Does the 2006 GMC Canyon have a crankshaft sensor?
And if it does where is it located?
The camshaft actuator solenoid valve is located on the right side of the engine below the valve cover. It is held in with one 10mm bolt. Once the bolt is out, twist the solenoid while pulling it at the same time to remove. It’s easy to check to see if the screen is missing before purchasing a new one.
Many Chevrolet Colorado and GMC Canyon pick ups are having problems with P0014 and/or P0017 codes. This has to do with the correlation of the camshaft and crankshaft as the computer sees them. Idle can be affected and the vehicle can even stall. The culprit is almost always the camshaft actuator solenoid valve, not the crankshaft position sensor or a cam position sensor. There have been reports of rough idle and fluctuation as well. The solenoid affects the variable cam timing control. One of the tiny screens can wear and be disintegrated causing everything to goes nuts.:rolleyes:
After replacing the cam solenoid and clearing the code, change the engine oil to help insure any remnants of the screen will be removed from the engine. Here’s hoping it does no further damage. :eek:
http://www.denlorstools.com/shop/images/Colorado_Solenoid_Location.jpg
http://www.denlorstools.com/shop/images/Cam_Solenoid.jpg
AFTERMARKET PART NUMBERS- A/C DELCO 213-1557, STANDARD PC403, DURALAST SU1486, Dealer part numbers: 8125840790, 12584079. AROUND 30 BUCKS.
