fjgeorge
Hi and greetings as this is my first post. I have a 2000 GMC Jimmy/Envoy and it has 172200 miles. I just replaced the following, plugs,wires, cap&rotor 2 02 sensors, and when I go to heavy accelleration from a stop it sputters like cuts out,doesn't die but I have to back off the throttle to go. No engine lights on either,does this sound like the Crankshaft Position Sensor? Thank you for the help.
Also another issue I have is when I press the Tow/Haul button it seems as if the transmission disengages and it just revs the motor with no motion if pressed while I am driving in D or do you activate any certain way. Now this was happening before I had two shift sensors and the accumulator replaced a few months ago, i have been scared to try it out.
