door lock won't stop
mrsingle01
05 crew cab z71, door locks work fine and remote does too. but when you are going down the road if you hit a bump the door locks again. and random door ajar come across the message center. any help out there???
Check the wiring in the driver's side door boot. The ground insulation will break down and the wire will eventually break. The issue usually surfaces as intermittent door controls on the driver's side. If the problem is still intermittent after repairing the wiring and comes and goes with higher outside air temps, check the BCM for a cold solder.
