Mr. Remarkable
- Feb 3, 2011
I've got a 2001 Sierra with a 4.8 liter, that idles up and down (almost turns off) only on start up with the engine cold. Once the engine warms up, the idle levels out to normal. If I leave it sitting for a while and let the engine cool back down, which in this winter weather it takes just a couple of hours, it'll do it again. It started doing this when the temp dropped outside around 30 degrees. Anything above 30 degrees outside temp, it doesn't idle up and down on start up. Even if the engine is cold.
Any input would help, Thanks
_Mike
_Mike
