I have a 1995 GMC Jimmy 4x4, it is hard to start up but when it starts the engine will serge at 1500rpm. If I let it idle and give it gas for a while it won't serge at 1500rpm but than it will at 2100rpm. Also the engine sometimes bogs down almost to the point of quitting. I have replaced the distributor cap and rotor, air filter and checked spark plugs they look fine and run injector cleaner through it.
And when the engine bogs down the rpms go up 500 and down 500 but it mostly just serge's and does not bog down as much any more.
Thanks in advance.
Thanks in advance.
