Front End Squeal
Combatant
Looking for some feedback on some ideas with a problem I've been having if possible. I am getting a front end squeal in my 2007 GMC Sierra 1500, and the weird thing is it only happens while I'm turning the wheel right of centre. Even the slightest correction will produce the squeal, and nothing while turning left. If you can think of anything please feel free. Thanks very much.
Wheel bearing going bad causing your brake rotor to rub against your pads. You may address the issue by having your Sierra's wheel checked and adjusted for proper alignment, this may buy you some time before your wheel bearing is finally passed it acceptable tolerance rate.
Good luck and keep us posted;)
I'm gonna lift the front end up and check the play in the hub.
Inspect your rotors also to see if there is a ridge from where your brake pads are cutting in to your rotors. The ridge will make contact to the worn pads indicator that makes the squealing brake noise.
Good luck and stay safe
Molson02536;)
Hello Combatant,
I see that you have gotten some great advice from some of the other community members regarding this noise you are experiencing in your Sierra. If you plan on taking your Sierra to a GMC dealership at all in regard to this concern, I would be more than happy to assist you in setting up an appointment and working with you and the dealership. Please feel free to private message me if you would like my assistance.
Gregory W.
GMC Customer Care
