GM announces 6 recalls covering nearly 720k cars
Filed under: Recalls, Safety, Buick, Cadillac, Chevrolet, GM, GMC
General Motors has announced yet another sprawling recall campaign, with six separate elements covering 717,950 vehicles on US roads. At this point in 2014, it's starting to seem like there are more days with a GM recall than without. Perhaps most troubling about this latest volley, though, is that every vehicle is from the past few years, indicating that GM's quality woes may not be limited to pre-bankruptcy vehicles.
The largest element of this latest campaign covers 414,333 units, and includes the 2011 to 2012 Chevrolet Camaro, 2010 to 2012 Chevy Equinox, GMC Terrain and Cadillac SRX and the 2011 to 2012 Buick Regal and LaCrosse. Only vehicles with powered, height-adjustable seats are covered. In these particular cars and crossovers, the bolt that secures the height adjuster actuator may loosen of its own accord and in some cases fall out completely. If this happens, the seats will be able to move both up and down. GM claims the vehicles are safe to drive, provided drivers don't vertically adjust their seats. This particular issue has caused one crash and three injuries.
The largest element of this latest campaign covers 414,333 units, including the Chevrolet Camaro and Equinox, GMC Terrain, Cadillac SRX and the Buick Regal and LaCrosse.
Next up, the 2014 Chevrolet Caprice and SS, 2013 to 2014 Cadillac ATS, 2014 CTS and ELR, 2013 to 2014 Buick Encore and 2014 to 2015 GMC Sierra and Chevy Silverado pickups (both light-duty and heavy duty models) are being recalled due to an "incomplete weld on the seat hook bracket assembly." 124,008 vehicles are affected by this problem, which is being blamed on a sudden loss of power to a laser welder at factories. Dealers will inspect the weld and replace the seat track if necessary. However, GM claims that less than one percent of welds will require track replacement. There have been no reported accidents or injuries for this issue.
The Buick Regal is getting pinged with a second recall, covering 2011 to 2013 models. It's joined by the 2013 Chevy Malibu, in an action that covers 120,426 vehicles. This is the least severe of the latest round of issues, though, as it has to do with the turn signal bulbs. These vehicles use a pair of bulbs in the signal array. Should both bulbs burn out, the driver is notified in the typical fashion (a rapidly flashing signal in the instrument cluster). If only one bulb burns out, though, there is no way of warning the driver. Unsurprisingly, this issue hasn't lead to any crashes, while the fix requires a simple reprogramming.
The 2014 Chevy Impala is also the subject of an action that's particular to models with belt-driven electric power steering. A bad electric ground to the power steering control module can lead to sudden loss or reduction in steering assistance. The car won't become uncontrollable, although owners will be forced to live with manual steering until a trip to the dealer can be arranged. GM is blaming paint that may have gotten behind a nut on a "power steering control module ground stud" for this problem. There are no crashes being blamed on this issue.
Korean-built Chevy Spark minicars from model years 2014 and 2015 are being recalled, in an action that covers some 1,900 units. In this particular case, GM is claiming the lower control arm bolt was not fastened to specs, which, in a worst-case scenario, could lead to a separation of the control arm from the steering knuckle. Dealers will take a look at both control arms to assure they've been tightened to specs.
Finally, 22 units from the new-for-2015 Chevy Tahoe, Suburban, GMC Yukon and Yukon Denali SUV range are being recalled due to poorly connected interior roof rails. An incorrect retaining nut is being blamed for the problem, which could puncture or tear the roof-mounted airbags, should they deploy. Of the 22 units in this action, eight are currently in dealer inventories.
GM has summarized this latest recall in the press release below. Scroll down for a look.Continue reading GM announces 6 recalls covering nearly 720k cars
GM announces 6 recalls covering nearly 720k cars originally appeared on Autoblog on Wed, 23 Jul 2014 14:30:00 EST. Please see our terms for use of feeds.
