gmc sonoma/ s10 need help wont start?
ninja530
my truck was running good and all of a sudden it shut off it. it will work in a few minutes but then shuts down after like i minute of working any ideas on what it might be.
it is a v6 4.3 1998
Have the Alternator Checked Out by a Local Shop. Have them put an Alternator Testing Machine on your Car, and see what they say.
Check your Battery Terminals for Corrosion. Replace your Battery, if the Corrosion has covered the Terminal. Use a Wire-Brush on the Terminal, and Remove the Positive Cabel from the Battery if you can.
If it's Rusted/Corroded bad enough that it's Stuck, then you Really Need a New Battery!!
Use some Pliers if this Happens, and Do Not Round the Nut off!!
Sounds like your alternator is not holding its charge you need to the battery have it tested good luck
