Ok, I own a 1996 GMC Jimmy, that has a cracked heater core because radiator fluid leaks into my car cabin. I am wanting to replace the heater core, or bypass the heater core. But where is this located? Behind the dash? Is it easy or hard to replace/fix?
Also, I have to add water/radiator fluid every day. But when I add it past a certain spot, it starts leaking out the bottom of my car. I am able to drive my car without over heating even though this happens. But when I stop and park the car (turn off) radiator fluid comes pouring out the bottom of my car again. So I can only stop my car about 3 times before I have to refill the radiator as far as it goes until it leaks out the bottom, or I will overheat BADLY.
Is that linked with the heater core? Or is that something new?
Thanks
Thanks
