chrisinestes
- Aug 29, 2011
I sure could use some help deciphering the specs on my 99 Sierra 1500 SLE 4x4.
The alignment place said it was as close as they could get to be within spec because of warn parts other than ball joints. At the time (2015), the ball joints were all great, since then a boot has slipped off, and it filled with crap, and it's warn and needs replacing.
Camber, Caster, Cross Camber, and Cross Castor are out of spec. What parts, beside ball joints, can cause that? My uneducated guess is the never-replaced suspension bushings... Am I right?
I've attached a jpg of the alignment spec sheet so maybe somebody can help me figure out what else, beside ball joints, I need to replace.
Thanks!
Chris
Thanks!
Chris
