HELP!!!! I have a GMC Envoy?
ramona
HELP!!! I have a GMC Envoy and the heater fan in the front portion of the car stoped working...I can feel the heat coming out and it works in the back...When i push the heater button on the car it blinks twice and shuts off....it stayed on when it worked...what is going on?
The problem is with your vehicle is that it was built poorly with cheap parts by a broke car company.
1 Check to see if the cabin air filter is clogged with dirt.
2 Check to see if the fan is jammed or stuck
3 If those don't fix it the fan my be junk and need to be replaced
Before any conclusion I would check witch option of the vent currently selected, to fase to leg to window? Front vent will work if option to face is selected
