help
cbsrab
My a/c in the rear of my van does not blow out cool air. The a/c switch works just fine, and the fan in the FRONT of the van works fine. It goes from low to high, but the REAR a/c fan will not blow the cold air into the back of the van. Can someone please help me figure this out? I would be grateful. Thanks. ---Clarence
Start with the simple and check all your fusses and relay, replace any that may have gone bad. The other issue also is that the wire harness connected to the blower motor may have melted from the high current if the blower motor is left in the highest setting for long period or time causing you to loose connection.
Here is a link to the rear blower on the back of the Savana, sorry i had to take a guess on what year your Savana is, but i believe that are all the same.
http://www.compnine.com/index.php?u...delid=7026&capuid=1&majorgroup=09&grouptype=B
