Hi from Iceland
Ice Falcon
Keflavik Iceland
Hi to you all here and greetings from Snowy Iceland
I have a Suburban 2500 year 1996 and it has been on a 31 inch tires
now i am in middle of Projekt rebuilding the front and put under a Dana 60 Front housing and 44 inch Tires from DC and have finished and only thing left there is to put Fender flares on the Sides
Now i am Working in the rear and have removed the 14 bolt GM housing and put in a Dana 80 with 4.10 and true track locker i have moved this housing a 8 inches more aft and cut of the sides to make a room for the tires
No body lift
Hope i finish this Modification in the End of the Month to put the Car in the Paint shop where he will be painted Fire Engine Red
those rims i use for the tires are 16.5 " tall and 19 " wide with bedlocks and will be hard to rip off the tire
More as the progress goes ,,, until then let those pictures tell the Story
I use a front fourlink system from RAM 2500 and could use it as it was
Spring tower fits perfectly and was welded to the Chassis
All the Old stuff ripped off
Some pictures from the process which has finished now and the Truck is driving on a 46 inch tires today
have to put a reverse Steering box from Chevy Express 3500 Van in him to get the right angle for the steering rod in the front of the housing :)
For the Fourling for the Truck Chassis
and for the Housing
The Real Stuff a 48mm Pipes with 4mm wide walls and mercedes Truck rubbers
And finally ready to rollin and waiting for a Paintwork in the New Year
