M mrrooferboy New member Joined Jun 11, 2011 Messages 3 Reaction score 0 Points 0 Jun 11, 2011 #1 what would cause the high beams to stop working on an o2 sierra 2500hd. all other lights work and i checked all fuses that i could find.
H happy 2011 New member Joined Apr 6, 2011 Messages 540 Reaction score 0 Points 0 Location new hampshire Jun 11, 2011 #2 Did you check the bulbs..... I seen many times both bulbs bad.
M mrrooferboy New member Joined Jun 11, 2011 Messages 3 Reaction score 0 Points 0 Jun 11, 2011 #3 2 new bulbs and no high beams
Z Z15 New member Joined Jun 2, 2010 Messages 443 Reaction score 0 Points 0 Location Michigan Jun 11, 2011 #4 dimmer switch is usually the reason.
M mrrooferboy New member Joined Jun 11, 2011 Messages 3 Reaction score 0 Points 0 Jun 15, 2011 #5 the high beams for my plow lights work. wouldn't they be effected also.
H happy 2011 New member Joined Apr 6, 2011 Messages 540 Reaction score 0 Points 0 Location new hampshire Jun 15, 2011 #6 then you need to check if the change over box for the plow lights get power in and then see if you get power out (for high beams) of the box.
K kniki10 New member Joined May 5, 2011 Messages 11 Reaction score 0 Points 0 Jun 16, 2011 #7 May be there is loose connections at the rear of the headlight, if you dont find it then you can it to a dealer.
