It's very doubtful that any timing related issues are caused by the chain. Normally when someone refers to timing problems, its ignition timing, via the distributor/ignition module/ECM.
This can be tweaked/checked by loosening the hold-down bolt at the base of the distributor, hooking a timing light to the #1 Cylinder, and aiming the gun at the timing marks at the crankshaft pulley. Turning the distributor either way will cause the timing marks to move, and that is how you check/set your timing.
Your engine however cannot be changed. It has a set strategy, and if that strategy fails, the module must be replaced.
If you had problems with the chain, the engine wouldn't start.
