On most cars the oil light isn't a signal that it needs changing, it's a signal that there is a problem with the oil pressure or temperature. Continued running of your engine with the oil light on may result in engine damage or total failure. I highly recommend that you get your car in to a qualified mechanic. You may have a problem with your oil pump, or a pressure leak.
