how do you replace fuel lines on a 1994 gmc sonoma?
g i
its leaking from the middle of the body towards the front of the doors. i dont have the money to get it fixed and i need the truck to get to college and work.
You can section the line where it's leaking with a rubber fuel line hose, make sure you buy a fuel injected rubber fuel line and use compression clamps to ensure no leaks. Common place for the fuel line to leak is where the line is secured to the frame by the plastic clips. You can pop the line off the clip and use a pipe cutter to cut the bad part of the line and replace it with the rubber fuel line and clamp with the compression clamp, you can double clamp if you like. Note try not to section off more then 3 inches of line, I my self when sectioning off the bad part of the fuel line will try not to take to much off if any. I may just cut the line where the damage is and place the hose over ether end and double compression clamp the hose with 1.5 inch on ether side of the leak. This should cost you $25.00 for parts and tools if you don't have a pipe cutter at Parts Source or NAPA. Good luck and keep me posted friend.
