how do you rmove a door on a 2001 gmc sierra?
Aniceto
the hinges are welded on all i see is 2 sma
ll pins on each hinge how would i remove those
the hinges are welded on all i see is 2 smaqll pins on each hinge how would i remove those
Those hinges are a pain.First,prop up the rear of the door then drive the hinge pins out,sort of like taking the hinge pin out of a house door.The spring will be in the way and hard to put back in without a tool to compress it.
open door look between door and body remove like 6 bolts might take 30 minutes
