Huge oil leak help
FASTQUEST
Hey every one,well i have a 95 jimmy 4x4 4.3 vortec and out of no were leaking oil like crazy.the truck never leaked and i mean never,so climbed under it and the driver side is covered in oil and determind it is comeing from the back/side of engine.thought oil sending nope,valve cover nope,oil pan nope,the oil cooler adapter yes.the lines comeing from it were the lines bolt to is leaking.got the part but how the hell do you change those lines?front diff is blocking the bolt.
This is the wife/kids car so any help i would be so thanks full
Remote oil filter
I just replaced this same line last night. You may not like to hear this but the best bet is lifting the engine a inch or so. I opted for the block of wood and jack under the oil pan. Most people say you need to take an engine mount bolt out but this wasn't needed. Just make sure you clean the mating surface of the filter cap and high pressure hose, getting the line installed with an old sealing gasket still there will cause more trouble than you think.
