I am not getting any fire to the fuel pump on a 1993 GMC Sonoma Pickup. What
Joey C
should I check for.? I have installed a new fuel pump and a new fuel pump relay also the oil pressure switch. But I still cant get the pump to come on. Had this problem once before and had to put it in the shop. They got it running but did not tell me what all they did. Can anyone help me? cant afford another shop bill.
check ur fuse box..see if u have fuse in fusebox for fuel pump...did u change fuel filters too ?
did you check the fuse for the pump if it is good check for a broken ground wire
The mechanic by law has to tell you if you ask, call them and have them check their records, which they have to keep by law. If they don't help, threaten them with the Better Business Bureau. *Always get everything in writing, always!
