I cannot remove the ignition key from my 1997 GMC Sonoma?
trimbe_88
I have 1997 GMC Sonoma. I cannot remove the ignition key. I can shut the engine off but it will not turn back enough to release the key.
bout 250 dollars @ a dealer or 45-75 diy, go to auto zone Or local auto store and get a new ignition. it takes about an hour to install (if you poke around with it) also a haynes manual wouldnt hurt. if you have an air bag, which you probably do, you should let the pros handle it.
