i have a 1996 GMC Jimmy help me!?
Tyler E
This car has been great, but HORRIBLE at the same time. I recently replaced the tranny and it was doing fine but now when i take off, no power and the rpm's go up and down...also when i shift from park to any gear or from one gear to another, CLUNK!!! also my fuse keeps blowing, no tail lights or speedometer lights. I dont know what to do, Iam about to drive this car off a cliff!!!!!!!!
Before guessing at transmission problems, check the fluid level (car warmed up, engine running in Park on level ground) and have the PCM scanned for trouble codes FIRST. This guide is meant for problems that do not show up as PCM codes (like shift A&B solenoid failures, for example).
NOTE:The transmission is on the same fuse as the MAF, O2 sensors and at least one other sensor - if an O2 shorts out, it will blow the fuse and the trans will go into limp-home mode. Be sure the trans has power and the fuse is not blown before doing anything else.
Also note that many problems that show up as transmission issues are actually PCM or electrical, and may be external to the transmission. Try a different PCM, and check for chafing where the cables come out of the PCM.
Secondly, put a line pressure gauge (or visit a local trans shop) on the pressure test port and go for a drive to verify proper line pressure. Base pressure at idle in P,N,OD should be around 70psi and around 140psi in R. Max line pressure should be at least 190psi at WOT in 1st or 2nd, 225psi is optimum. If base pressure is low, trans or pump is worn out. If max pressure is low, check EPC solenoid. If reverse is slow to engage, and line pressure does not come up to at least 130psi in reverse, replace the boost valve with a Transgo 0.490"-0.470" boost valve (easy fix in pan)
What is "limp-home mode" ? This is a fault mode in which the transmission either loses electrical power or the PCM deactivates all of the electronics. The transmission will default to max line pressure. The driver will have Reverse and 3rd, with manual 2nd available by putting the gearshift in 2 or 1 (doesn't matter). 1st, 4th, and TCC lockup will not be available. It will not hurt the car to drive it like this for short periods, but use manual 2nd to get the car moving, and be aware that the trans will generate more heat than normal while operating in limp-home mode due to increased torque converter slippage during 2nd gear starts and no lockup in 3rd gear.
1. Trans shifts into gear harshly, car feels sluggish off the line, No 1st, 4th or TCC lockup available, Manual 2nd, 3rd and Reverse are only available gears, CEL is on: Transmision is either in limp-home mode or has lost electrical power. If there are lots of error codes in the PCM, check the underhood fuse that powers the transmission, and if it pops again, look for a short in that circuit like an O2 sensor harness touching exhaust. Otherwise, check PCM codes for a particular fault in the transmission causing the PCM to put it in limp-home mode.
2. Shift suddenly become very hard. When going from park to either reverse or drive it slams into gear. 1-2 and 2-3 shifts are also harsh. All gears seems to work. Problem may be intermittent: Check TPS for smooth electrical response. If the response is jumpy or erratic at all, replace TPS.
3. Extremely harsh shifts from P or N, normal shifts at WOT: EPC (Electronic Pressure Control) solenoid failed. Easy fix in pan. Fix as soon as possible or hard parts will eventually break.:eek:
Before you go driving it off a cliff, inspect your electrical system for any signs of short that is causing your electrical issues. Here is a link to your electrical harness to your jimmy. :rolleyes:
http://www.compnine.com/index.php?t...=T&makecode=LG&grouptype=B&modelid=6872&uid=1
