i have a 1997 gmc sonoma i had a starter put on it?
Phillip
i drove it for about a week now it won't start at all there a click in the glove box where there are relay switch i bought one and try it still won't start
Check your battery leads & starter lead. It sounds like you have a bad connection from the battery to the starter. Clean the leads & battery terminals then tighten them on this should give you a better result. Hope this helps.
Check your battery cables at the battery and at the starter motor. Check that you have a fully charged battery and good clean connections. I'm not aware of a relay switch in the glove box. Do you have the 4.3 V6 engine ?
