Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
🔍 Like our community? You can tell Google to show you results from this site more often. Just Click Here and then click the empty checkbox on the right side of our name.
Sounds like the start solenoid has gone bad. First check the wire leads to the starter to make sure it's not corroded off or damaged in anyway that your starter and solenoid is not getting any power.
Keep use posted and we can go from there, Auto Zone or Parts Source can check your starter for you when you remove it. Always have the starter or alternator tested before buying a replacement part, just to make sure your not spending any more money then you have to.
