1993gmcsonoma2.5l
- Jan 31, 2013
ok i have a 1993 gmc sonoma sl 2.5l 4 cylinder and i have a problem with it dying when it gets hot. we thought it may have been the fuel pump but it wasnt it so i have replaced the throttle position sensor (tps) and the idle air control sensor (IAC) and the fuel injector on top of the throttle body and a fuel filter. it runs fine when you first start it when everything is cold but as soon it gets over a 100 degrees it dies and then when you try to start it again it wont start until you manuely put gas into the throttle body and also we checked the fuel pressure regulator and it looked excellent so can somebody please help me im going crazy!!!!!!!
