Increasing 2008-2500HD GVWR to 3500 HD GVWR
DPAM
Calgary, Alberta
I would like to increase my GVWR from 9200 lbs to be the same as the GVWR of a 3500 HD, which is 9900 lbs. I'm told I simply have to add an additional leaf spring, plus I have to have the same tires as a 3500 HD. Does anyone know if this correct?
Once I make the required changes to have the increased GVWR is it possible to get GM to change the door sticker on my truck door to state my GVWR is now 9900lbs, which is the same as a 3500 HD.
I greatly appreciate input from people that have experience with this matter.
Thank you.
Regards,
David
