2000 Envoy (Jimmy style) and a coolant leak.
Intake manifold gasket was replaced in the summer, heater core flushed and regained heating back. Thermostat was also changed at same time. New radiator cap.
Now it's winter, the temperature gauge does not get off the 100 deg mark. Little heat coming into the vehicle.
Noticed today a stream of coolant coming out from underneath but could no replicate it once it stopped. I can't see any obvious place where the leak is. I am guessing it could be the weep hole in the water pump.
Oil is not milky and I can see no oil floating in the coolant mixture, so I am pretty sure it's not the intake gasket again.
Any ideas other than pressure testing to see where it leaks?
What would cause the temp gauge not to move, failed thermostat?
Any help appreciated.
