keep getting a 2 lean codes and ramdom misfire
lavonanthony
i have changed the coal canister the gas tank filler neck, gas cap, MAF, and i keep getting the lean codes on bank 1 and bank 2, and random misfire. can sum 1 help me out here please.
sounds like a vacuum leak? pos .but year make and model and motor size would be nice. also are you using scan tool ?
I had the same issue for months on my 2001 savana it ended up being a vacuum leak and the way I found it was by waiting for the engine to cool remove the air filter and cap the hole where it inserts into the airbox then remove the console in the van pull the PCV valve out plug the hole on the valve cover disconnect the PCV valve from the hose and spray extra soapy water all around the engine then blow into the hose and look for bubbles. My leak was at the throttle body where the intake connects. HOPE THIS HELPS
