key stuck in ignition
Jenny
I have a 2000 jimmy the key won't turn all the way and I can't get it out of the ignition.
If it's anything like mine, there is a small hole underneath your ignition (on the bottom side of your steering column) you should be able to fit the back end of a pen in there. I'm not sure if there is a screw there or not but if there is, remove the screw and push the back end of the pen up the whole. You should be able to turn your key and get it out. This is really hard to deascribe, so if you don't know what I mean, just reply back. I hope all works well.
