Str8KoKayne
- May 5, 2013
hey guys,
i have a 1997 gmc jimmy 4.3 v6 and my keyless entry is acing weird. the remote i have only unlocks the drivers door, not all the doors even tho i press it twice within 5 seconds, and the hatch button pops the window also. the lock button doesn't work at all and the other 3 doors stay locked. i tryed re programing it like this and it didnt work.
Transmitter Programming
Ground pin 4 to pin 8 of the data link connector (DLC). The receiver will respond as follows:
The doors will lock and unlock within 2 seconds. (here the other locks didnt cycle at all only my drivers door)
The liftgate window release (E54) will be activated within 2 seconds. (the rear window worked here)
Simultaneously press and hold the LOCK and UNLOCK buttons on one of the transmitters until the locks cycle. This will take approximately 10 seconds. The receiver will respond as follows:
Do not wait more then 60 seconds between transmitters or the receiver will exit the programming mode.
Repeat step 2 for each transmitter, four transmitter can be programed to this vehicle.
Remove the jumper wire from the DLC.
Verify that the RKE is functioning correctly:
Lock and unlock the doors.
Activate the liftgate window (E54).
all the doors unlock with the button on my drivers side door pannel though. Any ideas? help will me much appreciated i been trying to figure this out for a while now. thanks guys
Luke
Luke
