hpyjack2013
- Dec 12, 2013
Have 2008 Sierra. Came with factory aluminum wheels(i guess) I'm constantly having to put air in them. Has anybody else had this problem?
Actually, if you want to fix them all you need to do is take one of the ones that is loosing air off, put your spare on. Now take it somewhere and have them dismount the tire. Take the tire and rim home.
Take the rim and clean off the lip as best as you can. I use lacquer thinner. Then take 400 sand paper and sand the inner lip smooth getting rid of any corrosion. Then take a rattle can of primer and prime the inner lips. If you would like you can then use 600 sand paper and scuff em up again and then shoot another coat of primer on it. BAM......good for another 100k![]()
