TheLostGoat
Hi All-
Long time lurker first time poster. I'm coming at you with a pretty rookie question but hopefully you can help me out. I have searched but didnt find anything directly related.
Long story short a shop 1/2 a state away replaced both rear wheel cylinders and a right rear brake line. Ever since then, i have to press the brake pedal 1/2 way to the floor before I feel the brakes kick in. I've also noticed that I need to push my emergency brake down all the way to get it to hold now.
I've bled the brakes over and over, replaced the master cylinder and had the ABS unit bled by a dealership- still no change.
Is it possible that my rear drums are not adjusted properly? My plan is to raise the rear end and adjust the star wheel until I feel resistance when spinning the wheel, then back the adjuster off just a little bit.
Am I going in the right direction? Thanks all.
