ok this is what happend, I have a 1998 gmc savana with a 5.7. The van has 99000 miles and was skipping so my thought was to bring it in for a tune up, plugs, wires,....etc. I used a local garage that i have used before and had no issues with, they also have a pretty good rep. The owner did the work on the van. He replaced the plugs, wires, rotor, cap, fuel filter, pcv valve, and added a fuel conditioner to the gas. When I got the van he told me that the timing was 15 degrees off and he adjusted it to a relearn computer on the motor. This was a little strainge to me because the truck ran fine before, just a skip at 70-80 mph. I just thought at that time that he knew what he was doing and got in the truck and drove away. About 60 miles down the highway was my exit, I got off highway and the van idol went up down up down up down..... drove for another 5 miles and it just shut off. tried to start and it would half turn over and stop. Kinda felt like a dead batt.. Had my fathers mechanic tow to his garage and asses the issue. He told me the mechanic that I had do the work should have not touched the timing because the van will automatically adjust the timing when a new cap and rotor is installed, in other words the guy screwed up the timing so bad it dropped the oil pressure and burnt a berring in the engine. IS THIS EVEN POSSABLE?? THIS SUCKS ALL I WANTED WAS A TUNE UP NOT A TUNE DOWN
Start with the simple and are you sure you lost oil pressure??? The ECM will cut the fuel pump when the oil drops less then 6 psi so you don't burn out the crank bearings.
If your mechanic did try to adjust the timing by rotating the distributor, there could be a good chance that that the crankshaft position sensor is command up to 50 extra degrees of spark advance during engine cranking only. This in turn exposes the engine to higher than normal cylinder pressures which may result in an no start condition or with these symptoms:
1. Backfire during crank/start
2. "Kickback" during crank/start
3. "No" start
4. "Slow" or "hard" start/crank
5. "Grinding" or unusual noises during crank/start
6. Cracked or broken engine block at the starter boss
7. Broken starter drive housing
8. Broken starter ring gear on flywheel
Or any combination of the above mentioned.
Here is a class on how the timing is done on the vortec and you will need a scan tool to set it.
Below is the text from GM Service manual for 1998
Chevrolet C Pickup 5.0L, 5.7L, and 7.4L
According to this you don't set the timing but the timing offset.
You need a "Scan Tool" that plugs into the truck and can read the data from the trucks computer.
Besides from that, it looks like a normal timing procedure.
Setting Timing
Camshaft Retard Offset Test
The ignition timing cannot be adjusted. The distributor may need adjusting to prevent crossfire. To insure proper alignment of the distributor, perform the following:
With the ignition OFF, install a scan tool to the DLC.
Start the engine and bring to normal operating temperature.
Important
Cam Retard Offset reading will not be accurate below 1000 RPM
Increase engine speed to 1000 RPM.
Monitor the Cam Retard Offset.
If the Cam Retard indicates a value of 0° ± 2°, the distributor is properly adjusted.
If the Cam Retard does not indicate 0° ± 2°, the distributor must be adjusted.
Adjusting Camshaft Retard Offset
With the engine OFF, slightly loosen the distributor hold down bolt.
Important: Cam Retard Offset reading will not be accurate below 1000 RPM
Start the engine and raise engine speed to 1000 RPM.
Using a scan tool monitor Cam Retard Offset.
Rotate the distributor as follows:
To compensate for a negative reading, rotate the distributor in the counterclockwise direction.
To compensate for a positive reading, rotate the distributor in the clockwise direction.
Repeat step 4 until 0° ±2° is obtained.
Turn the ignition OFF.
Tighten the distributor hold-down bolt to 3N•m(25 lb. ft.).
Start the engine, raise engine speed to 1000 RPM and recheck Camshaft Retard Offset.
Start with scanning your ECM for any codes and re-check your timing and go from there.
Hope this helps and keep us posted
