J Joshua New member Joined Nov 16, 2009 Messages 7 Reaction score 0 Points 0 May 5, 2010 #1 I tilt it back to turn em off and it wont shut off. Nothing clicks when i do it and i dont wanna get a ticket for having em on.
N nightro New member Joined May 5, 2010 Messages 1 Reaction score 0 Points 0 May 5, 2010 #2 The Internal Switch In The Steering Column Is Broken. You Will Have To Replace It.
M Molson02536 New member Joined Dec 9, 2009 Messages 3,123 Reaction score 0 Points 0 Location K/W Ontario Canada May 5, 2010 #3 nightro said: The Internal Switch In The Steering Column Is Broken. You Will Have To Replace It. Click to expand... Try removing your DRL relay, if the DRL relay is bad. It will keep your High beams on, if the relay is good, then replace the stock switch as mentioned by nightro Good luck and keep us posted.
