my 92 gmc jimmy has the left tail light out and front and back left...
dano5479
...signal out, fuse is fine? the front left turn signal doesn turn on, and the back left tail light doesnt turn on at all, we replaces some fuses and the blinker in the front tarted to work for a while, but went back out..
Sounds like a corroded light socket, common for the light socket it self to corroded after a few years and your Jimmy has more then a few years on the light socket. Simple pix and you can buy the replacement socket at most auto parts store like Auto Zone, just make sure you pick up the right ones.
Good luck and the common sockets that go bad is the front sockets, causing the whole light system to go bad on that side. Replace both sides since there the same age and your most like will encounter this issue again on the other side. :eek:
