Need help bad on front end issues!!!
rebelrouzer
I have a 95 GMC Sierra ext cab. I have been having some trouble with it recently. I had a major vibration which i found out to be the carrier bearing on the drive shaft, changed it. So now (and it has been doing this since I got the truck 3 years ago) for some reason when it is wet out and any time I loose traction and the rears spin, the wheel alignment gets thrown way outta wack. Like what should be 12 oclock is now at 10 oclock. this seems to get rectified only when I make a 90 degree turn to the right. also I have a lot of wheel "jiggle" when cruising and tonight at one point I thought my truck turned into a snake as the rear was slithering opposite from the way the front was "slithering". Please if anyone has an idea of what the hell the problem can be let me know. I drive a lot for work and do not want to be stranded or worse yet get into an accident.
