rebelrouzer
- Dec 15, 2012
I have a 95 GMC Sierra ext cab 2wd. I have had this problem for a long time and now it is really bad. When it is wet out and I loose traction and the rear tires slide, my steering wheel goes from 12 oclock to 10 oclock. It goes back to normal after I make a 90 degree turn to the right. Now tonight the steering wheel started to "jiggle" back and forth a lot and some how my truck turned into a snake and started "slithering" down the road. Not fishtailing but "slithering". I have also noticed that when cruising the engine would kinda surge a bit and it will shake like heavy rumble but stops as soon as I let off the gas and then its fine again for a bit but a few minutes later it will start again. I doubt the two are connected but tonight I thought I was about to wreck her. Please if anyone has any ideas let me know.
I crawled under it and tried to see if the tierod ends hand any play in them but it dosent seem like it.
