Need to locate heated seat wiring harness for 2008 denali
Bryce000
Alaska
The previous owner replaced the passenger door with a 2500hd panel, I want to replace it with the original denali panel so I can use the passenger heated seat function. I pulled the panel off and there is no harness in the door for the heated seat switch. I know the passenger seat is heated because it turns on with the remote start. So I'm trying to find where the wiring harness for that switch begins so I can have it ready for when I replace the panel. Thanks
Bryce, I think there are two plugs that enter the door from the side. I would think that there would be an empty connector right at that location if you are not finding the harness. Hit up you local stealership and they should be able to find the part, or hit the local pick n pull to have a lock at a door. Or, how about checking out www.car-part.com............ more than likely it will not drill down to that specific part, but, it will give you names and #'s of junk yards in your area. Make sure they have a Denali and call em up, they'll have the part. Usually 50% less than stealership cost is the going rate.
