Okay, so I just purchased my burban a week ago. It was an emergency purchase as my prior vehicle's motor seized and I needed something quick and reasonably priced. Thus the burban.
Here's the issue that I'm having, though -
When I test drove it, I noticed an extremely slight pulling to the right that was more pronounced on braking, but nothing concerning.
The engine bay was clean but not spotless and I didn't notice any leaks or drips on the under carriage.
After a couple of days of driving it I noticed a sizable fluid spot on my garage floor. Looking at the under carriage the fluid is dripping down apparently from under the master cylinder and is spraying onto the frame and into the wheel well.
There is generally a tablespoon or so of new fluid on the ground after being parked each night and the fluid on the frame is wet and fresh after each drive. The fluid is reddish in color, which makes me think it is power steering fluid.
Another issue that has started since I've noticed the leak is that the truck pulls hard to the right on braking. I assume that the pads on the left have been fouled by fluid, but haven't pulled them yet to see. It may also be a completely disconnected issue, though I think there must be some connection.
At any rate, I plan to work on it this weekend, but wanted to reach out to see if anyone has any ideas of what might be causing the issue, i.e., any known issues with the power steering system on these vehicles that I should look at first? The challenge is that I have a single vehicle and if the parts store or dealer in my small town do not have the parts, it is an hour drive to the next town that might have parts, so I want to round up as many as possible before the weekend when I start tearing into things.
Thanks in advance for any insight you can offer.
