New Vehicle Procedures
AATA
I'm picking up a new 2011 GMC Sierra Crew Cab with the 5.3L/6 Speed and was wondering if anyone can provide information on break-in cycle (or if it's even neccesary on newer cars) and when to change the oil the first time. I'm assuming they put some kind of break-in oil from the factory. I plan to run A synthetic like Mobil 1, but I know it's sometimes not good to put it in until the engine breaks in.
Any other tips for a new GMC owner would be appreciated as well.
Thank you!
No such thing as break in oil, not needed with today engines.
The best thing you can do for a new vehicle is to driver at moderate speeds, vary your speed for the first few hundred miles and not drive for long periods at any one speed. Avoid towing and hauling heavy loads for the first 500 miles, no sudden stops etc.
You can use synthetic oil from the get go if you want, its a myth that engines require break in before using synthetic oil.
Many new cars come with synthetic oil, Corvette's, Cadillac's, Honda's, Toyota's, Fords.
Mike
2010 GMC Sierra SLT ECSB All Terrain Z71
2009 Cadillac CTS4 AWD Performance Sedan
I disagree with the above statment. no offence!
my truck came with 100% synthetic oil.. so you can goto mobile 1 whenever you want..
thats the same oil i use.. and very happy with it and my truck ... i have 18,000km on my
2011 truck 5.3/6spd
http://www.mototuneusa.com/break_in_secrets.htm
check out this link... this is the way i break in every engine..
anyhow... i think the light easy driving what the owners manual says is for safety!!
cheers
Warts
2011 truck 5.3/6spd
cheers
Warts
good luck with a warranty issue following that procedure...you can risk your new 40K truck....not me!
You're wrong about the break in oil. A lot of the top racing oil companies produce it and it had friction modifiers in it to help with break in. I know a lot of race teams that use it, but we just use dino oil in our race car for break in for the first few hours. I just wasn't sure if it's neccessary for an engine coming from the factory. I assume they run them before they ship them out?
I think I'm just going to change it within the first 500-1000 miles to drain any small particles and start putting a synthetic from now on.
The factory cars you mentioned may already be broken in on a dyno, so they drain it and put synthetic.
Thank for the input!
The subject of this question was new vehicle break in and not racing engines, my answer was in that context. Comparing racing engine to new vehicle engines is comparing apples to oranges.
All vehicles are put on a dyno at the assembly plant but not to break in the engine. They have to pass emissions certification and all systems (engine, braking etc) must be calibrated before shipping. So every vehicle probably has at min 1 hr of engine run time from the moment it is started on the line to the point it is driven off the truck at the dealer. The vehicle is driven out of the plant to the storage yard, its driven from the storage yard onto the train. Its then driven off the train at rail yard point of delivery, they driven onto the truck, driven off the truck at the dealer. So as you see, it did not magically appear at the dealer before you got it and you are not the first person to drive.
Do they run the engines at the engine plant before they ship them, No they have other means to test them without firing them up. Do they run the engines on regular oil and then change them over to synthetic? No. Can you imagine what that would cost them in $ and man hours? Do you really think they are going to put in oil, run the engine 5 min and then put in more expensive oil? No way, no how.
They ship them with synthetic oil because its the better oil to use in those vehicles. All new 2011+ GM vehicles are shipping with dexos1 spec oil and so far almost all oils that meet that spec are synthetic oil. Do you really think GM is changing oil on nearly 1 million vehicles before they get to the dealer?
Also, its a myth that engines will not break in on synthetic oil. The Corvettes been factory filled with synthetic oil for nearly 20 yrs.
This is right from GMtehclink
http://www.sandyblogs.com/techlink/2007/12/
The Synthetic Oil Myth -- Then there is the myth that new engine break-in will not occur with synthetic oils. This one was apparently started by an aircraft engine manufacturer who put out a bulletin that said so. The fact is that Mobil 1 synthetic oil has been the factory-fill for many thousands of engines. Clearly, they have broken in quite well, and that should put this one to rest.
Not likely as people will believe what they want to believe.
Oh No. Say its not so, GM is installing synthetic oil is all its vehicles and requiring it for warranty.
fyi.........................................................................
Article from LUBE REPORT ()
July 21, 2010
Shell Embraces, Valvoline Snubs Dexos
By George Gill
While Shell will offer engine oils under its General Motors’ Dexos license and more than 20 other marketers have applied for licenses, Valvoline has given Dexos the cold shoulder, citing cost concerns.
Dexos 2, designed for use in passenger car diesel engines, launched last year in Europe. Its gasoline-fueled counterpart, Dexos 1, must be available globally for GM’s 2011 model year vehicles. The Dexos specifications use performance tests from ILSAC and Europe’s ACEA, plus some proprietary GM tests. (GM calls its trademarked specification “dexos.”)
GM recently announced that Shell, the world’s largest lubricant supplier, is now licensed to manufacture and market Dexos engine oil. Dexos is required for all GM Buick, Chevrolet, Cadillac and GMC vehicles starting with the 2011 model year. Shell’s initial Dexos licensed offerings are Pennzoil Platinum and Quaker State Ultimate Durability synthetic engine oils.
“Shell synthetic oil is factory fill-approved by GM, and Pennzoil Platinum and Quaker State Ultimate Durability oils are available for consumer use,” Debbie Van Schalkwyk, Global Pennzoil brand manager, told Lube Report.
While Shell would not say what size market it anticipates for Dexos, Van Schalkwyk noted that Dexos oils, while required by GM for new 2011 vehicles, are backward compatible. “Conventional motor oils are not capable of meeting Dexos,” she pointed out. “It stands to be seen whether or not owners of pre-2011 cars, especially the larger population who use conventional motor oils, will use Dexos oils.”
Pete Sant, Global Shell passenger car motor oil product technology manager, said the company’s lubricant blending plants required no changes to accommodate Dexos. “The additive packages for Dexos fit nicely into our system and no upgrades or modifications were required to produce Pennzoil Platinum and Quaker State Ultimate Durability motor oils meeting Dexos specifications,” Sant told Lube Report. “Shell's international team of scientists worked with additive providers to develop Dexos oils.”
Valvoline, a division of Ashland, stated it will not officially license Dexos to minimize the cost impact to customers who would be replacing GF-4 motor oils with Dexos motor oils. The company asserted that its SynPower MST 5W-30 already meets Dexos 2 requirements and can be used in all GM passenger car gasoline and diesel vehicles. In the fall, Valvoline plans to introduce a product that meets the Dexos 1 specification. Valvoline said use of the product it is currently formulating for GM vehicles will not void the vehicle warranties.
“Our reasons for not licensing Dexos boil down to our belief that industry specifications are the best and most efficient solution for all parties, including our customers,” Ashland spokesman Jim Vitak told Lube Report. “Dexos further proliferates the number of products that must be stocked by distributors, installers and retailers, and adds unnecessary further complexity for consumers. Further, the licensing fees proposed by GM are cost prohibitive, and would result in significantly higher costs for the motoring public.”
General Motors in March confirmed plans to switch the licensing fee on Dexos from a royalty on every gallon of Dexos sold to a flat annual fee based on an oil company’s market share, a GM official confirmed to Lube Report. Originally, licensees were to have paid a $1,000 annual fee for each product, plus a royalty of 36 cents on every gallon of Dexos they sell. Sources suggested GM considers the fee a “flat” one in that GM looks at market shares today and then calculates what an oil marketer’s fee will be over the next four years.
While acknowledging Dexos marks a significant shift from how the industry has traditionally set engine oil specifications, GM said it believes it is moving in the right direction.
“The benefits of using Dexos include improved fuel economy, better engine protection and reduced emissions,” said Eric Johnson, senior project manager for GM Powertrain. “Dexos allows GM to ensure the same high quality oil is available worldwide and, in doing so, realizes the economic benefits of consolidating the numerous GM engine oil specifications down to two.”
According to GM, the new specifications provide enhanced performance in the areas needed by GM engine technology. For example, the company pointed out that nearly all current GM engines use cam phasing. “A key criteria of the oil is sufficient engine oil aeration control so that the hydraulic valve actuation used in these systems functions optimally. In this area, the Dexos specification contains a used oil aeration test.” According to GM, no such test exists with GF-5.
GM also cites multi-fueled vehicles as another factor. Approximately 50 percent of General Motors engines will be fuel flexible by 2011. “In addition to a number of other areas, Dexos 1 also exceeds GF-5 in corrosion protection, important for multi-fueled vehicles, and piston cleanliness, important for engine operation and durability.”
The Center for Quality Assurance in Midland, Mich., serves as program administrator for Dexos licensing. Jo Lynne Parsons, project manager for the Center, said other key drivers for the Dexos program were GM’s concerns about engine tests becoming obsolete, and the need to educate consumers and ensure the right oil for the vehicle was easily identifiable. “One of the drivers of the program was to generate funds to offset a portion of the engine test development costs and their maintenance, in addition to monitoring the quality of the licensed oils in the market,” Parsons explained.
To assist in identification, the Dexos icon/brand needs to be displayed on the front of the label and the license number displayed on the back. “The icon makes it easy to identify while the license number shows it’s authentic,” she added.
The Center indicated interest in licensing has been strong. Three additive companies now have formulations approved, and a significant number of marketers of various sizes worldwide are already licensed or in the process of becoming licensed, the Center stated. “More than 20 companies have applied to date, and we continue to receive additional inquiries from companies of all sizes,” Parsons told Lube Report.
The Dexos license makes sense for companies of various sizes, Parsons said. “We have several small and medium-sized companies holding or seeking a license,” she noted. “However, if some smaller companies don’t think it fits this business model to become licensed as a blender, they can purchase Dexos product from a licensed blender and rebrand it.”
Parsons emphasized that the Center for Quality Assurance will guide applicants through the process. “Upon notification that a company is interested in seeking a license, the CQA will respond with information regarding license procedures and associates fees.”
The process to become licensed is relatively simple, according to Parsons. “Applicants submit completed documents and a 20-liter retain sample,” she explained. “Some routine bench tests are run on the retain sample to establish a baseline and confirm compliance. Notification of compliance and execution of the license agreement follows. A unique license number is assigned, and a certificate of license issued.”
Published by LNG Publishing Co., Inc.
Copyright © 2011 LNG Publishing Co., Inc. All rights reserved.
George Gill, Editor. Lube Report (ISSN 1547-3392) is published by LNG Publishing Co., Inc., 6105-G Arlington Blvd., Falls Church, Virginia 22044 USA. Phone: (703) 536-0800. Fax: (703) 536-0803. Website: www.LNGpublishing.com. Email: info@LNGpublishing.com. For advertising information contact Gloria Steinberg Briskin at (800) 474-8654 or (703) 536-7676 or gloria@LNGpublishing.com.
Powered by IMN
