My son's trans went out so I am in the process of a rebuild. only apparent issue I have found is the bearing that goes from input shaft to main shaft. From literature I have found it is called a pocket bearing. The only part number (if that is what you want to call it ) I have found is K25/40/15 which is really the metric dimensions of the bearing. The rollers are steel and it ha a plastic cage. There are NO numbers or markings at all on the cage. I wonder if anyone has been here and has info for me. I have been searching all day on multiple bearing websites with no luck at all. just looking for a number for cross reference or actual part number.
Thanks in advance
Phil
Thanks in advance
Phil
