1989 GMC s15 automatic 4 cylinder ...
I found that there is very low compression in 2nd and 3rd cyl. like about 0 psi or 5 psi but 1st and 4th cyl. have 125 psi
is 125 psi ok or it is sill low?
also, truck was running ...can it run on 2 cylinders? not the best but was still running...never gave me any problem.
and is there any other reason why it shows very low compression in 2nd and 3rd apart from either valves or lower engine problem?
Before I take it apart...I want to make sure nothing else is causing this?
