Hi: new here but hoping someone can help me. I have a 2006 sierra When I start up the truck the cluster is out. a few seconds later it powers up but the 4 gauges do not. The speedo and tach work. The battery , check engine and abs lights stay on. The radio also will not work. The radio will work when i shut the truck off with the doors closed. I checked all the fuses and the grounds under the door on the frame. This happened all at once,was working then was not. I checked power to the fuse box and have 12v on the orange wires and power on the pink wires with the key on. Thank You.
