griffintlc
After replacing the sealed beam headlights because the driver's side high beam quit working, I found the high beam still doesn't work on the driver's side. There are separate fuses for each side and each beam (hi and low). They look good. The wiring to the headlight looks good. Have yet to check to see if power is at the plug, but I feel there is none at the high beam terminal in the plug.
The vehicle is 2004 Savana 3500
Any suggestions?
Any suggestions?
